Hey, I'm rather new to Maya and I'm having a bit of trouble doing a project for one of my 3D classes.
The project is to sculpt an animal head on Mudbox, do the topology on Maya to make a lower resolution model, do the Uvs, than go back to Mudbox to make a texture.
My issues is with the Uvs. The teacher gave us specific easy steps on how to do this using an example, but I cannot get them to work. His example was an ape head, so he basically did the ears separately by cutting the edges of a loop, did a plannar in Z, cut edges in the back of the head in a T shape (going down the back of the head and neck), unfolded it and that was it.
My problem is that I'm doing a doe, so the head and face structure is very different from an ape. When I do what he told us to do, nothing unfold properly and it's kind of a mess. I think what's mostly giving me trouble is that long snout and long neck. Not to mention the ears are completely different as well.
I was wondering if anyone knew how I could unfold the Uvs in similar manner as the teacher, because I'm kind of stuck.
I took some screenshots to provide a visual of what I'm working too.
Thanks in advance
Hey @Anathema_ so in general UV mapping is like the dishwashing of 3D modeling, very boring but essential :P. If you can attach the actual model I can try and break it down for you but to quickly summarize you would want to shift select one edge that goes up and down across the does head and then do another one that goes left to right. These are to mark the seams for the texture. I did a quick paint over to mark where I would have the seams. Also you would do the ears separately like your professor did. I know this might be hard to understand just reading it but give it your best shot and if you cant figure it out attach the obj and I'd be happy to give a more in depth break down :).
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
