[Need help] Collada file generate from osm
- I use JOSM plugin (Kendzi3D) generate 3d building from osm & export to collada file
- Cant delete edge, I try to repeat but it show result: polyDelEdge1,2,3,....98,99,
- Try to use "Combine" to combine all building part & delete edge but not work
- Try to delete face and use "Fill Hole" but not work...
ScreenshotScreenshot
***File in use, see below (Export from Kendzi3D, 5MB)
Ps. Sorry for my english
mspeer
Hi!
The faces are not connected, you can move them individually.
Try:
Edit Mesh -> Merge
