I have been all over tutorials and following them to the "T" but my nCloth still does not stay on the pole
I am expecting it to stick to. I created a canvas, shaped it as needed and then converted it to an burlap material
I create the poles into a passive collider from nCloth. Placed the burlap over the poles selected the poles and burlap
went to vertex and selected the vertexes that I wanted to attach. I then under nConstraint --> Point to Surface.
I select the first frame hit place the the burlap material falls through the poles. It looks like a cloth material but
I can never get it to attach! Please tell me what I am doing incorrectly!!
Solved by faline.custodio.da.silva. Go to Solution.
Created a quick screencast for you. The problem with how you were doing it was the way you were making the selection before creating the constraint.
I have written down your instructions and followed them but STILL I cannot attach Canvas
I downloaded this screencast but do not know how to get it to you
Thomas Hanson
I've attached the file from the screencast. Check it out and compare it to what you have setup.
I'm happy to help you with any further questions you have.
Cheers
