Ncloth Scrunchie
Ncloth Scrunchie
Ncloth Scrunchie
I am trying to figure out a good way to create a Hair Scrunchie with Ncloth by maybe scrunching up a torus. Does anyone know how I could do this?
mcw0
It all depends on what you want to do with this.  If it's just a static model, why not start with your torus.  And then use a texture deformer with some stretched noise?  There will be a seam issue.  But maybe repeat the texture with mirror to try to hide the seam.
Thank you! That worked I used the noise deformer to get the basic shape and then pulled verts around a bit.
