Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
It may be that your normals are reversed and you have single-sided lighting selected. The lighting option is in your model pane - it's a check-box called "two-sided lighting". If you don't have that box checked, you have single sided lighting, the side opposite the normals will appear black.
Might also be a disconnect between your model and the shader, but I doubt it. you can try re-assigning the shader or assigning a new one - but it looks like the lighitng is your problem.
