For some reason I am no longer able to select multiple sets of vertices to be merged at the same time, only a single set of vertices that will be merged. For example I used to be able to select all of the vertices in a while mesh and merge them all at the same time, now I have to zoom in and ONLY merge those that will become a single vert. Any ideas? Thanks in advance!! (Maya 2017 update 3)
Solved by Alexaendergfx. Go to Solution.
Hey @Alexaendergfx I just tried this out on my scene by selecting 6 vertices and hitting merge to center and it worked fine. You could try deleting your settings/preferences and see if that fixes is it. If not feel free to post back with some screenshots/video and let me know if I can help
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
