Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Maya switched my working units from MM to CM (wont switch back right) and wont export correctly.
0 REPLIES 0
Message 1 of 1
videogames2theend
214 Views, 0 Replies
-Howdy, I have been using maya for a few years for 3d printing parts. It is very important that when I exported objects from maya they are the size they say they are in maya.
-I have had my working units for all my projects (even render room) use MM
-Well maya recently switched on all my projects to be CM, it switched a 5mm object to be a 5cm object. I tried switching my units back to MM. But maya then changed the 5cm object (that was 5mm) to be 50mm which is way to big.
-Also when I export an object, and import it, the size is totally wrong. For example I exported an object as 2.661 CM but when imported to all other programs I tried (prusa slicer, lychee)  to comes out as being 3.16MM.
Does anyone know what to do, and why I get these issues.
I desperately need maya to work right now. I need to have things be converted back to being in the right MM size, and for Maya to export objects correctly.
Any help would be greatly appreciated
0 REPLIES 0
