I was working on my project and it was working normally, but one day when I went to open the file to work on it MAYA came up blank. No grid, no project, no shelves. It's not just this project file, any time I open MAYA this happens. I thought it was because my start up disk was almost full, but I've cleared up a lot of space and even uninstalled and reinstalled MAYA. I'm not sure what else I can do, but I am working on a deadline and don't want to lose all the work I've done.
Solved by hlw1181. Go to Solution.
Solved by damaggio. Go to Solution.
For some reason the folder look up cannot be found. Not sure if I'm formatting the version wrong by I've tried a bunch of different variations
Update! Reseting the prefs folder did the trick! Since I'm on the student version I had to access the folder in a slightly different way. This solution worked for me better than doing "Go to Folder..." Thanks for the help!
