Maya Insert Edge Loop Symmetry Not Working
I am fairly new to Maya and I am working with adding edge loops to harden edges. I have applied symmetry to the World X on the Move Tool and the object is centered at the origin. I have reset the Insert Edge Loop Tool as well however when I go to insert a new edge loop, a preview is not shown on the opposite side and the end result is an incomplete edge loop that is not symmetrical to the one I placed. Any help on this issue would be greatly appreciated! Thanks.
Its_jay
maybe there is gap between your model somewhere
check that area
Centre you axis then place your object on the world centre then modify > freeze transformations and then try symmetry.
I am also new but someone gave me this answer and it worked fine.
