Maya 2018: XGen Expression Editor does not open
Message 1 of 18
Hey Maya Pros!
I am recently having issues with the XGen Expression Editor in Maya 2018.1.
When I click the Expression Icon beneath the slider for the parameter I want to edit, no Expression Editor Window opens.
I already tried to reset my user preferences for Maya, but the problem still occured.
When I open the Maya Script Editor I get the message:
# Traceback (most recent call last):
# File "C:\Program Files\Autodesk\Maya2018\plug-ins\xgen\scripts\xgenm\ui\widgets\xgExpressionUI.py", line 1981, in showEditor
# self.xgExprEditor = XgExprEditor(self.attr, self.value(), cpal, cdesc, _mayaMainWindow)
# TypeError: # 'XgExprEditor.XgExprEditor' called with wrong argument types:
# XgExprEditor.XgExprEditor(str, str, str, str, PySide2.QtWidgets.QWidget)
# Supported signatures:
XgExprEditor.XgExprEditor(unicode, unicode, unicode, unicode, PySide2.QtWidgets.QWidget = None)
Hope somebody can help me out 🙂
Replies (17)
Message 2 of 18
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Message 3 of 18
Hi!
Unfortunately I already tried that, but it did not work....
I started Maya 2018.1 with the default Maya Prefs, everything (including window Layout) was set back, but I still could not open
the XGen Expression Editor 😞
Maybe there is another way to open the Editor via a custom script?..
Message 4 of 18
mspeer
Hi!
You are right, it does not work.
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Message 5 of 18
Hey!
Already done 🙂
I will post the answer of Autodesk if I receive any!
Message 6 of 18
Nadja.Bueckmann
Hi @Anonymous,
thanks a lot for pointing out the issue. I could reproduce it on my system.
The issue is already logged with our development team and they are already working on the issue.
Best, Nadja
Nadja Bueckmann
Technical Support Specialist – M&E (3ds Max, Maya)
Message 7 of 18
What's the ETA on a fix for this? It breaks some pretty crucial functionality.
Message 8 of 18
i had (and have) the same problem.
Load any expression from the dropdown menu, after that you get a expression inputfield.
Message 9 of 18
Message 10 of 18
Hi, this bug breaks basic functionality of Xgen. Any ETA on a fix? Thanks.
Message 11 of 18
Alex.NGX
Did anyone find a workaround this one?
Message 12 of 18
This is absolutely ridiculous!!! I was working on a character for a month and suddenly xgen breaks? wth?????
 TypeError: # 'XgExprEditor.XgExprEditor' called with wrong argument types: blah blah
the simplest thing that you can do these days is to paint on something in 3d packages. why do I need to spend 10 hours trying to ENABLE? painting maps? seriously?
Message 13 of 18
Has this been solved yet?
Message 14 of 18
mspeer
Hi!
It's fixed in Maya 2018 Update 2.
Message 15 of 18
Wonderful! Has anyone here tried this out?
Message 16 of 18
No. Using 2010 if I ever need to open a Maya scene.
Message 17 of 18
Hi, I have this same problem with xgen, in my maya 2018 and now 2019. I just reinstalled both and still doesn't work :
I don't see any unicode character in my path... any idea to solve this problem?
Message 18 of 18
This worked for me. I duplicated my prefs folder [just incase], and deleted the files in the original prefs folder. Once I relaunched Maya 2018, the XGen editor launched.
