Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Maya 2017 - Selecting specific set of faces that are the same
1 REPLY 1
lucascarci17
431 Views, 1 Reply
So I've been working with Maya for a number of years now, since 2012, and I've always had the difficulty with selecting faces. Specific ones. For example:
I Generate a sphere (20x20 subdivisions)
Then select all the faces, and hit the extrude function.
I change the extrusion by choosing to not have the faces attached, so they extrude as separate "beams".
But instead, I shrink the size of the extrusion and chamfer the vertices.
I want to re-select the faces I just had selected, so I may delete them. How is this possible in Maya? Is it even possible?
Attached are photos of what I am describing.
Thanks!
(In the photo, the selected faces are the ones I wish to select without having to go about selecting them all manually.)
1 REPLY 1
_sebastian_f
in reply to: lucascarci17
select one of the desired faces and go to:
select > select similar.
you maybe have to play with the similarity tolerance.
