Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Is there a way to set the coordinates of curve points?
DarioBr
DarioBr
Is there a way to set the coordinates of curve points? That would be extremely helpful. Currently I am creating cubes and using curve snap, but I am sure there is a better method.
stuzzz
Hello
Your question miss some important informations. What kind of curve are you doing? CV, EP, bezier? What degree?
by the way here's python snippet that would help:
cmds.selectPref(trackSelectionOrder=True)
indices = cmds.ls( fl=True, orderedSelection = True)
poses= []
for index in indices:
	poses.append(cmds.pointPosition(index, w=True))
cmds.curve(d=3, p=poses)
Select your cube's vertices (order matters) then launch this script and it will create a curve having its CVs snapped to the selected vertices.
second method (best one?):
Select the edges of the cube then Modify->Convert->polygon Edges to Curves
