I've encountered this a number of times but never bothered to see if this is possible. Often, when putting in an edge loop to tighten a corner, for instance, I will decide I need to slide the current edge loop closer to the edge but the "Slide Edge Loop" tool will snap even when snapping is disabled. It will not allow, or I cannot seem to make the tool, nudge the loop closer to my desired location without snapping. What I have usually done in these circumstances is used the "Insert Edge Loop" tool and simply placed a new edge loop where I really want the current edge loop to be and then simply selected and deleted the old edge loop. Seems to me their ought to be a way to nudge a loop either with a move, or scale transform or using the "Slide Edge Loop" command but I cannot seem to find it.
128Gb, 4Tb
Sonoma 14.6.1
MacDisplay, Dell U3415W
