I would like to move multiple vertices the same distance in different directions
vordermand
vordermand
Hello people,
I would like to move these vertices as such. This is going to be a TV screen. I want the one vertex to move X amount to the right, the other one X (the same) amount to the top, and I want to do this for all 4 corners of the screen. So the same value for 4 different directions, for 8 vertices. The move settings in the Modeling Toolkit aren't precise enough.
Kahylan
Hi!
If it needs to be this exact, you're probably best of using code to do it.
Here is a python program, it moves selected vertexes in worldspace as much as specified in the last line:
import maya.cmds as mc
def moveVtx(x = 0,y= 0, z= 0):
    sel = mc.ls(selection = True)
    for s in sel:
        mc.move(x,y,z,s, r= True, ws = True)
moveVtx(x = 0.5, y = 0,z = 0)
So all you need to do is select each vertex, change the value in the code and execute it from a Python tab.
I hope this helps!
hamsterHamster
same thing possible with existing UI
here, the function of the same code snippet could be done with RelativeTransform fields and MoveTool selected; saves script editing and execution.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
