I select faces on one side of building and faces on other side of building also get choosen
womp_1FDJBL
womp_1FDJBL
Trying to put a texture on one side of building model
When selecting faces on ONE side of model, the opposite
side face of the model also get chosen.
I have read "Disable pick chooser for comonents", followed the
instructions saved then shut down Maya and reopened it again
to have the exact same thing happen again when selecting faces
What's the work around??   I have Maya 2020.4
mcw0
Is it a symmetrical building?  If so, might the other half be an instance?
mihirsbcc
Or Symmetry is on.
brentmc
As others have said check to see whether you have symmetry enabled. (in the status line at the top)
If the issue is that faces behind the ones you are selecting getting selected then you can enable "Camera Based Selection". (which can be accessed in the select tool setting or in the Modeling Toolkit)
Turn it On to only select components on the front of your model. You can also set it to Auto which enables or disables it depending on whether you are in Shaded or Wireframe display.
Brent
Brent McPherson
Principle Software Developer
