I just can't do the Quad raw on my model after combining the other objects together
koa888
Message 1 of 10
koa888
Hello Everyone, I had this problem when I finished combining many objects to one final object and when I did the Quad raw the point just couldn't appear on my model. Anyone has had this problem before? Please help!
I have added my file to this post for you guys to check!
Thank you so much!!!
Replies (9)
Message 2 of 10
mspeer
Hi!
This is just an empty scene!?
Message 3 of 10
Kahylan
Hi!
Something went wrong with your upload, because it's just and empty scene at our end.
But just a guess, could it be that you didn't put your object into live mode?
Generally for quaddraw to stick to an object you need to turn it "live".
Which you can do by selecting the object and clicking on the button below.
I hope this helps!
Message 4 of 10
koa888
Ok, I have added a new file, just my mistake.
Message 5 of 10
koa888
Ok, I have added a new file, just forgot the same name file.
Message 6 of 10
koa888
No, my friend, I choose the object and hit the live button then nothing happened, I tried with other parts and it works but this object just has no response.
Message 7 of 10
Kahylan
I could open it now.
The reason you can't use quaddraw, is because your normals are inside out. Quaddraw can only be used on the front side of polygons.
You can better see which side polygons are facing by turinging on "Backface Culling" in your Viewports Shading tab, which makes polygons transparent when looked at from the back side.
You can fix this by selecting all the polygons in face mode and then using the Mesh "Display> Reverse" command.
I hope this helps!
Message 8 of 10
koa888
Wow,  you just save my life Kahylan, this is so informative for me. Thank you so much, my friend!!!
Message 9 of 10
koa888
Can I ask about this new problem? I now can use Quad Raw but the points are not on the surface, they are just hanging over the surface and don't even touch the surface. What is the problem with this?
Thank you so much!
Message 10 of 10
Kahylan
I think I had a similar issue once and it turned out to be a problem with your scale. Your object is rather small, which can cause selection tolerance issues. Try to scale up both the object you snap to and the quad draw object by a factor of 10. If they don't have the same pivot, group them first and then scale the group.
Maybe that solves your problem?
Otherwise please attach the scene so I can take a closer look at how exactly quad draw is misbehaving.
Have a nice day!
