How to reset tools settings in Maya 2018
I'm new to Maya, earlier everything was working well.
but from few days i'm unable to select the gizmo and move objects, even rotate and scale option is also not working.
I tried this too,
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
So, kindly help with the appropriate solution.
hi,
if i've understood your problem maybe you have locked the transition, rotation and scale of your object! To unlock them go to channel box, select the parameters about these transformation, once selected them right click and UNLOCK SELECTED, try this and let me know if it works..
Can you explain me using some screen shots please.
yes, I don't know if your problem is this, but if it does follow this steps:Screen Shot 2018-03-12 at 07.57.39.pngScreen Shot 2018-03-12 at 07.57.50.pngScreen Shot 2018-03-12 at 07.58.00.pngScreen Shot 2018-03-12 at 07.58.06.png
