Hi everyone! I built a window and want to insert it into a wall. I have no idea how to go about this. I tried using booleans but there are a ton of problems, especially when considering the shape of the window, the vertices left behind from the boolean, and the mess it will be during retopo. Any suggestions on how best to go about this? You can see the screenshots below as my example of what I'm trying to do.
I also tried duplicating the faces on the outside of the arch, and booleaning them through the wall. The problem comes with the massive amount of leftover verts that now would need to be merged. How would an architectural modeler handle this?
