Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I am working on making a dinosaur mouth and every time I move a single vertex it starts freaking out. I made sure to merge all the vertices together, and even use clean up. But once I move any vertex around the mouth. it messes up.
Solved by mspeer. Go to Solution.
This happens to me all the time. Currently i'm facing the same problem but when this occurs i literally close maya without saving only way i know how to fix this >.>.
When I quit without saving it still happens so its definitely something I did wrong. But yea when I don't touch anything it looks fine but when I move anything around the mouth it blows up. Its also weird because you cant select the messed up triangle faces either.
Hi!
You have some edges connected to more than 2 faces (inside the mouth), correct this and it will work.
Edit:
You could also switch Smooth Mesh Preview to "Maya Catmull-Clark" but i highly recommend to correct the mesh anyway.
