How to find out instance or duplicate?
maeyoshi
maeyoshi
Hi, I was just wondering about how to find out if an object is a duplicate or instance of another object. Any ideas?
damaggio
You can name the instances "Copies" , you can also color them in the Outliner.
Kahylan
If you turn on "shapes" in your Outliners "Display" menu and expand the objects. You'll see that instances are linked to the same shape node, while copies have their own shape node.
I hope this helps!
maeyoshi
Thank you so much!That helps a lot.
maeyoshi
Thanks!I’ll try that.
