Hi, all!
In the attached scene, I want to extrude pCube1 along polyToCurve1. I select the curve first, and then the cube. Then "Edit Mesh | Extrude" and... nothing happens ! What am I missing ?
Thanks in advance.
P.S : I use Maya 2017.
Solved by mspeer. Go to Solution.
Hi!
Only Components like faces and edges can be extruded along a curve path, so first select a face or an edge, then the curve and then use extrude.
How can you select a face and a curve if you need to be in select faces mode for selecting a face and you must switch to object mode in order to select your curve?.
Here's a step that it's not explained and this is why it doesn't work for me or I'm a real newbye in this.
Please, could you help me?.
This is a great tutorial for solve the problem
https://www.youtube.com/watch?v=4igTVJOEJw0&
