How to create low poly style models
Hey,
I'm trying to create low poly style models, and i have found a fairly simple way to do so. If you go into Maya, make a sphere for example and you delete a face by doing (ctrl del) then using the bridge tool it should make the object look like it is low poly but only in that section, is there a faster way to do this??
J450NP13
Use this.  But you may need to do some tweaking.
Yes i do know of the reduce tool and that is what i used to make the sphere look low poly in the wire-mesh but not showing on the poly
J450NP13
What do you mean it’s showing on the wire mesh but not the poly?
you can also use normal and bump maps to reduce poly count.
mspeer
Hi!
Main menu:
Mesh Display -> Harden Edge
Exactly what i wanted, thank you.
Thank you J450NP13 for trying to help me
