How to create bridge between multi polygon
combine the objects then do it.
when i select more than on faces and apply bridge in the same time the bridge connect with the wrong face
brentmc
Yes, you can select more than one face but the selected faces must be connected by edges. e.g. if you delete the selected faces you would be left with a single closed ring of border edges.
If you follow this rule of thumb and the result is twisted then adjust the bridge offset parameter to match up the edges correctly,
Good:
I suspect you have selected faces that are only connected by a single vertex and that is why the bridge is not working. e.g. does not form a single closed ring of border edges if deleted.
Bad:
Brent
Brent McPherson
Principle Engineer
