Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
How do I make 2 sets of joints affect the same mesh
wyattstagg
wyattstagg
I am trying to make 2 sets of joints equally affect a mesh and I cannot find out how to do so, an example of what I'm talking about would be the file attached https://mega.nz/#!w7I2FI4C!jD54aWNgXzQZe5lNNuwRxQYggKxiLW4mjnexpCULzCk
mspeer
Hi!
You can assign multiple skeletons/joints to the same mesh, that's not a problem.
If you want some sort of blending instead:
One way would be to create 2 separate objects with individual skeletons and use them as Blend Shapes.
wyattstagg
when I try to bind the second skeleton I get the error message that appears here
https://gyazo.com/a5fdb38ef487ec0b2b59916c94b17034
mspeer
Hi!
You can not bind a second one later, use Unbind Skin and then Bind Skin both at the same time.
Simply add it in it's history, use a script to get it under or above the older skin cluster!
YOU CAN HAVE TWO SKIN CLUSTERS ON 1 MESH VERY EASILY
