Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
How do I make 2 sets of joints affect the same mesh
4 REPLIES 4
wyattstagg
2391 Views, 4 Replies
I am trying to make 2 sets of joints equally affect a mesh and I cannot find out how to do so, an example of what I'm talking about would be the file attached https://mega.nz/#!w7I2FI4C!jD54aWNgXzQZe5lNNuwRxQYggKxiLW4mjnexpCULzCk
Tags (1)
4 REPLIES 4
mspeer
in reply to: wyattstagg
Hi!
You can assign multiple skeletons/joints to the same mesh, that's not a problem.
If you want some sort of blending instead:
One way would be to create 2 separate objects with individual skeletons and use them as Blend Shapes.
wyattstagg
in reply to: mspeer
when I try to bind the second skeleton I get the error message that appears here
https://gyazo.com/a5fdb38ef487ec0b2b59916c94b17034
mspeer
Hi!
You can not bind a second one later, use Unbind Skin and then Bind Skin both at the same time.
Simply add it in it's history, use a script to get it under or above the older skin cluster!
YOU CAN HAVE TWO SKIN CLUSTERS ON 1 MESH VERY EASILY
