Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Hole filling does not work
8 REPLIES 8
Message 1 of 9
The_Viruss
403 Views, 8 Replies
Hey everyone I have a problem. I want to fill the hole on the upper side, but it does not work ;( Please help thanks
8 REPLIES 8
Message 2 of 9
Generally you model things the way they're built. If there are separate parts you want to model them that way. In your case, looks like you're going real low poly so I'd aim to model one watertight mesh. If you're doing the latter, you don't want random unwelded vertices.
Message 3 of 9
The one from the first link is the outer wall
Message 4 of 9
And for the second link picture of you. It was locked, but the ceiling is gone now I'm trying to get that back.
Message 5 of 9
Lots of weird unwelded points. If that is one object you probably won't get a 'fill holes' function to work
Message 6 of 9
A bit hard to tell what 'hole' you're trying to fill.
Message 7 of 9
Okay got it working, but now the uv is a bit ****ed ;D how can I fix it ?
Message 8 of 9
damaggio
in reply to: The_Viruss
You need to watch some UV tutorials for beginners. Check the Autodesk learning channel
Message 9 of 9
amaterasu-qbb
Hi! @The_Viruss .
 Did this issue get resolved?
Select the UVs one by one, open the UV editor, execute Create's Normal-based, select the connected edges, open the marking menu with Shift+RMB, and execute Move and Sew Edges in the 12 o'clock direction.
