Help: rounded corners on single polygon
Is there an easy way to create a single n-sided polygon and then round the corners of it to a specific radius?
The attached image shows the effect that I'm going after. Start with a polygon, add radii the corners.
What I did to actually get this was: create the polygon, extrude it up into a volume, select the vertical edges of the extrude, apply an edge bevel, then select all the vertical faces and the top face and delete them leaving me with just the original face, but with radii.
I'd rather just create a poly, select the verts, add a radius.
I'll be doing this a lot - it's for a city mapping project and I don't think Nurbs curves are the right way to go here.
Ideas?
