Hard edge problems.
Hard edge problems.
Message 1 of 18
Hard edge problems.
Greetings everyone!
So i have bin moddeling for a pretty long time via Maya, I am still learning so much about it and about moddeling, however 1 problem never seems to disapear and that is hard edges.
Now I know that using booleans is a "no, no" from what i have heared atleast.
but without using booleans i get that same problem.
what is basicly is that somehow Maya creates hard edges that won't turn soft again, or sometimes with booleans it doesn't cut out the shape correctly and makes round things not fitting to the shape that I am cutting it out of.
My question is basicly, what can i do to stop does hard edges from showing up?
I added a picture where you can clearly see what I mean.
Greetings Jermaine
Replies (17)
Message 2 of 18
mujuningaiza
From showing up? How when rendered? Can you explain a bit more you needs? I thought you were after showing those hard edges when Modeling, but your attachment is a rendered image. Come on and make it clear, everything is possible
Message 3 of 18
Well this is a render to hightlight it, but it is shown in Maya itself to.
Message 4 of 18
mujuningaiza
Oh lord, no additional verts hidden if you used boolen operation? Attaching a scene might be something good
Message 5 of 18
greetings, so in this version i didn't do close up the faces to have just 4 vertex but you can see the problem easily in this. I don't understand why it does it and why it sometimes does it more and sometimes less..
Message 6 of 18
mujuningaiza
 Something is not right, here is what I see when I open your attached scene2016-12-16 (4).png
Message 7 of 18
mm that is really wierd... Let me save as obj.
Message 8 of 18
damaggio
Looks like all your boolean work is gone, you probably didn't clean your history, open your obj on a new file .
Message 9 of 18
damaggio
As mujunigaiza was probably guessing, you were getting hard edges because of bad topology, booleans that were not cleaned up, the model should be almost all quads and few triangles jermain, see if you can clean your file....and clean your histoty, always do incremental saves and keep file in .ma format not .mb.
Come back if you have questions.
Best.
Message 10 of 18
well the base of this model is very simple. But what it does is making it's own invicble edges. i can't see them it just creates this extra line i can't see.
The model shape like I said is very simple so it really should create this.
see this wireframe. The red is basicly pointed at an "edge" that isn't there...
The blue lines are basicly showing how they lines followed the shape without those round parts cut out.
hope this helps with explaining my (for me atleast) weird thing
Message 11 of 18
damaggio
You never gonna fix this the way it was modeled, this topology is not recommended, you have Ngons all over the place, you can leave as is and try to finish the model , render and paint over with photoshop all the little artifacts you see, and render not so close...or you can clean up the model or try another modeling method like SubD.
Message 12 of 18
damaggio
A good rule of thumb jermain is to mach the resolution of the Boolean object with the Iphone topology so you don't end up with so many extra vertices to clean up afterwards.
Message 13 of 18
mujuningaiza
Ok, am waiting for it.
Ngaiza Leonard Lymond
Message 14 of 18
I sended that 😉 it's in the RAR file. couldn't upload a OBJ file directly
Message 15 of 18
The ngons are not the problem. When they are fixed the problem is still there. It isn't going away like that.
I didn't close it to basicly show you how the "natural" shape is.
Message 16 of 18
mujuningaiza
The way you're modeling hard surface modeling is really bad at your topology. You have short Edges, verts un-connected, multiple edges nearby without neccessity. Look at this, boolean work as  jermainesmit tell you. 2016-12-17 (1).png2016-12-17.png2016-12-17 (2).png
Message 17 of 18
OK agree those parts are done bad but that is not the reason for the hard edges around the cut out.
See this pic. A new shape. Simpel shape. And without having n-gons you can see it still creates the problem.
Message 18 of 18
mujuningaiza
every shape you see becoming as a problem it's caused by how edge are flowing, you need to re-construct it again. Sad am too busy trying to fix that issue, but believe me if you modeling tools in Maya that issue would be fixed by using tools like Multicut, Delete Edge/Vertex, component connect. Delete some eges which are near each other, trying to select all verts and choose merge vertex, there might be double vertex you can't see, increase  merge threshhold see if the problem can be fixed
