GoZ opens new instance of Maya
23rakesh2015
Message 1 of 10
23rakesh2015
when I send object from maya to Zbrush it works fine but when I send from Zbrush to maya  it opens a new instance of maya everytime why?
Replies (9)
Message 2 of 10
Having the same annoying problem. Have you managed to find a solution that works?
Message 3 of 10
I have that same problem too , googled it but can't find a good solution 😞
Message 4 of 10
After you install goz from zbrush close it.
copy GoZBrushFromMaya.mel to C:\Program Files\Autodesk\Maya2018\plug-ins
From C:\Users\Public\Pixologic\GoZApps\Maya
also Copy userSetup.mel to C:\Users\username\Documents\maya\2018\scripts
from C:\Users\Public\Pixologic\GoZApps\Maya
https://www.artstation.com/cordova5252
Message 5 of 10
NO, Sir, it's not working Smiley Sad , I did like as said step by step (copying .mel files to main plug-ins folder, & the usersetup.mel to Ducuments script folder , & I made sure to open maya & activate the plugin from plugin manager,,, still doesn't work, each time it openes new instance of Maya each time, & the ((GOZ update)) button in maya doesn't send/update anything at all :S
I use Maya 2018.3 & ZBrush 2018.1 .. I am using another custom script called Styx OBJ Import Export & it works , till Pixologic fix their issues.
Message 6 of 10
emili0
Observer
Observer
Thanks.
This worked for me.
I just copied userSetup.mel, because the plug-in was already connected.
Message 7 of 10
This Works!
Message 8 of 10
Noo need to copy and paste anything from anywhere just duplicate the goz maya shelf button and change the command from 'gozfrommaya' to 'goztomaya'
Message 9 of 10
Well, the trick is this...As the solution says copy paste the userSetup.mel file from C:\Users\Public\Pixologic\GoZApps\Maya to C:\Users\username\Documents\maya\2018\scripts.
But, if you have already a userSetup.mel file with other information and mel scripts in it, just keep it at C:\Users\username\Documents\maya\scripts.
ONLY IF the userSetup.mel in maya/2018/scipts includes only the Zbrush command and nothing else, GOZ works perfectly (at least, for me 🙂 ). Good luck
Message 10 of 10
tannerellison3d
I had encountered the same problem when updating Zbrush this week. I already had a existing userSetup.mel file, so I added the below line from the Pixologic userSetup.mel file found in the goZ folder referenced above. My userSetup.mel file is located at C:\Users\<your name or whatever>\Documents\maya\2020\scripts so I cant speak to the various other places that userSetup file may show up!
eval("source \"C:/Users/Public/Pixologic/GoZApps/Maya/GoZScript.mel\"");
Works perfectly for me now!
