Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Getting weird polygon mesh when modelling
7 REPLIES 7
Message 1 of 8
barelvi66
1047 Views, 7 Replies
why my polygon mesh is getting really weird when im on Default polygon mesh display but i can select normally on my real polygon mesh, and when my polygon is in smooth mode(number 3 shortcut) it just works really fine, so i cant see properly when i want to edit the polygon. any idea how to fix this?, i ran this problem so many times before
7 REPLIES 7
Message 2 of 8
damaggio
in reply to: barelvi66
That looks like a video card glitch..does it happen on any scene?... is the card drive compatible? Try an update or a different viewport mode.
Message 3 of 8
barelvi66
in reply to: damaggio
Problem still exists, im on latest version on my GTX 950M
Message 4 of 8
damaggio
Let’s take a look at the scene file then, please zip it and upload
Message 5 of 8
barelvi66
here you go sir, please take a look
Message 6 of 8
damaggio
Sorry barelvi, cannot open .rar files, could you try again and use a zip utility instead.
Message 7 of 8
barelvi66
here you go
Message 8 of 8
damaggio
Thanks for the Zip Barelvi, here I have no artifacts switching from polygons to OpenSubd , the model is clean so I believe your card is not running well with your Maya version, if none of my suggestions worked for you then you might need to look into getting  a newer card or just try to work this way if possible for a little longer.
Sorry I can't think of anything else to help you.
