Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
extrude controls is not showing in maya 2016
9 REPLIES 9
Message 1 of 10
fabsrn
2019 Views, 9 Replies
HI guys,
I need some help when I try to extrude a geo maya 2016 is not showing the extrusion controls anymore anyone know whats going on??? but the extution works on Promitives
thanks
9 REPLIES 9
Message 2 of 10
damaggio
in reply to: fabsrn
You mean extrudes on a fresh primitive poly but not anymore on the mesh you are currently modeling?
Message 3 of 10
in reply to: fabsrn
Yes, do you know how to fix it?
Message 4 of 10
damaggio
in reply to: fabsrn
A couple of things you can try..: use the channel box after extrusion..: you can also export as obj and import back ..: you can reset the prefs folder ... You can try to close Maya and import into a new scene .
Message 5 of 10
in reply to: fabsrn
Has no channel Box everything gone I tried everything you said before but thank you
Message 6 of 10
pshwayka
You probably have construction history turned off. The icon shown below toggles it back on. (Looks like a clock.)
Message 7 of 10
fabsrn
in reply to: pshwayka
thank you Very much that was the problem
thanks mate!!!
Message 8 of 10
guy
in reply to: fabsrn
Okay so is it possible to run the bevel command and edit the settings without having history on?
If this is not possible this is going to be such a pain in the neck,due to the fact that having history on chugs my computer big time after 50-100 actions.
Please tell me ther's a way to do this.
Message 9 of 10
_sebastian_f
in reply to: guy
no it´s not possible without history.
but keeping that much history is not recommended at all so just delete it more often.
Message 10 of 10
nongthimay31797
that's my problem, thanks a lot
