Hello there! I stumbled upon the problem with simple extrusion along the curve path. For some reason, it starts to rotate the profile along the way and I have no idea how to turn it off. Also if I move any curve point the whole shape starts to rotate. The same twisting I get with extruding as a surface or sweep mesh. Any ideas?
And yes, I created the desirable result just for example and without any curves, but I did it only because of the simple shape, for more complicated paths I'll need the curves.
Solved by artfully3d. Go to Solution.
After the extrude, you could try changing the twist value. I had some luck with increasing this all the way to 180. It did make the end result a bit more consistent but perhaps still not as level as perhaps you are hoping for.
Another - better option would be using sweep mesh as you did try. But expand the options down to advanced and turn off "auto roll" (screenshot). But adjusting some settings I was able to match your happy-face version
