duplicate special
duplicate special
selvakvigneshmaya
duplicate special
selvakvigneshmaya
so i tried to mirror my first character design using DUPLICATe SPECIAL option but i cant get the result as we do by using mirror i  tried first with a polygon cube as u guys can see help me with this guys.ATTACHED THE VIDEO BELOW.
mspeer
Hi!
You need to remove the rotate value from your object, for example by using Freeze Transformations, or by adding a new transform node on top.
selvakvigneshmaya
thank u it worked may i know what happened when i apply free transform
mspeer
Hi!
Freeze Transformation bakes the component transformations (from the transform node) into the mesh.
selvakvigneshmaya
