Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Difficulty UV mapping when importing .obj from Blender
2 REPLIES 2
1832 Views, 2 Replies
I am trying to UV-map a mesh by doing the following:
1) Panels > Saved Layouts > Persp/UV Texture Editor
2) Select object, RMB > Assign new material > Lambert
3) Attributes Editor > Common Material Attributes > Color > Map button > Checkered
When I do this with a default Maya sphere, it works just fine.
However when I attempt this with a mesh that I have imported from Blender, it no longer works (it turns white instead of checkered textured).
I was wondering what the problem might be.
Thank you.
2 REPLIES 2
Ah, solved the problem. It was missing a UV set.
Solution:
1) Select Object
2) From menu, Create UVs > Automatic Mapping
n8skow
The automatic mapping will be fine for a solid color - but if you plan to replace your checker with a texture map - some cleanup will likely be required of the UV map as you will have many separate seams in the UV map.
