curve length
curve length
raptoreagle
Message 1 of 11
curve length
raptoreagle
i'm trying to create an oval shaped nurbs circle with a length or perimeter of 804cm. Getting the shape is not hard but i cant mesure the length of the oval.
please is there a way to do that? Thanks
Replies (10)
Message 2 of 11
damaggio
A Maya unit is equal 1 centimeter, each little square in the default grid is one centimeter, just scale your object to 804 units...you can use the measure tool under "Create>Measure tool...to guide you to 804 centimeters.
Message 3 of 11
raptoreagle
i replied by email but it didn't turn up here... i'm doing so here just incase
What i want is the oval to be of 804cm in length just the same way an olympic running track is 400m. i tried using the arc mesure tool but i didn't get any results.
thanks
Message 4 of 11
damaggio
use the distance tool not the arc....drag one locator until you reack 804 units and then scale your model to match it
Message 5 of 11
raptoreagle
the distance tool only mesures along a stright line. i need to mesure along a curve.
Message 6 of 11
_sebastian_f
arc length should be the tool you are looking for! just create it, click on the curve and set it to the maximum u value of your curve. scale the curve to the desired length - the tool should update in realtime.
Message 7 of 11
raptoreagle
ok!
i'll try that.
Message 8 of 11
raptoreagle
but i need the shape itself to have a length of 804cm. the same way an
olympic running track is 400m. that's why i said "perimeter"
ok lets say i wanted to build an olympic running track, how would i go
about that? i tried using the arc length tool but it doesn't give me what i
want.
thanks again.
Message 9 of 11
_sebastian_f
i understood that and when i use the arc length tool it´s exactly what it tells me. because it´s easier to check i did two circles. r=1 and r=2. when i create an arc length tool and put it on the end of the curve it works. so i don´t get what´s going wrong on your side!?
Message 10 of 11
raptoreagle
ignore the last reply! that was the reply i sent by mail to the first person who replied me. guess the reply by email system doesn't work lol!
i already accepted your advice as the solution. Thanks again.
Message 11 of 11
_sebastian_f
haha, ok seems that there was a "little" delay then.
was a bit confused but thought that maybe you accepted to fast and got another problem afterwards. anyway good that everything works as expected (but the email reply)!
