I am new to Maya, so I'm still learning the basics. I was wonder how one might make a straight, horizontal pipe, but the ends curved vertically?
e.g. ,---------,
Solved by LifeArtist. Go to Solution.
Hey,
if I have understood you correctly you want something like this:
Maybe there is another method using a curve creation method but I wouldn't know how to exactly create those curves. So this is what I did:
Edit: I would suggest setting the length divisions within the curve to tube mesh settings to 1 otherwise you have unequally spaced out edge loops within your tube.
Here are pictures of some stages:
LifeArtist
