I'm currently working on a new project, but I'm kind of stuck. What I try to create is something that should resemble water dripping (see "WAI-image"). As you can see it has a lot of round edges. I've been trying quite a lot of things but since I'm pretty new I can't figure out how to get it to look smooth.
Now I'm trying to make it again and what I have is this (see "WIP-image"). I've built it up like this (see "WIP-wireframe" image). I was wondering if someone might have an easy way to create this or some tips to help a beginner out!
I would like to get some feedback. Thanks in advance!
Solved by stuzzz. Go to Solution.
Wow, great! What option did you use? Did you use edge loops or is there also an option to split something in two?
thanks!
