Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Cleanup Mesh and NMG
I am attempting to load a Maya file into Mudbox and I've already ran Cleanup on it. There are no non-manifold errors when I run Cleanup and have the select option checked. However, when I try to load the file into Mudbox, there are two non-manifold errors(T-shape and vertex splice).
What am I doing wrong?
My theory is that I constructed the mesh in an improper way by using methods that would create NMG. But I am not sure why the NMG wouldn't be selected when I run Cleanup on the mesh.
I've attached the file if anyone can take a look.
Ben
mspeer
Hi!
"To detect such Problems use Mesh Component Display -> Display Borders."
"In short: re-create one of the adjacent faces of the corrupted edge and the Problem is solved:"
https://forums.autodesk.com/t5/maya-modeling/select-one-edge-and-another-one-moves/m-p/6630728/highl...
Thank you,
I tried searching the forums earlier and didn't know I'd find the issue with a different name.
Thanks again!
