Announcements
Circularize moving random vertices on a certain mesh
t_aliesinriver
Message 1 of 12
t_aliesinriver
On a certain object, when I use the circularize tool on any set of faces it doesn't work, and instead moves a random selection of other vertices across the mesh. When I try this on any other object, it works fine. It seems that other tools occasionally have the same issue. Has anyone run into this problem before, and do you know what could have caused it or why it happens?
Screenshots from before and after circularizing below:
Replies (11)
Message 2 of 12
t_aliesinriver
Adding that combining the mesh with another, non-cursed mesh seemed to fix the issue, but I still would like to know why it happened in the first place so I can avoid running into the same problem in future.
Message 3 of 12
Ιάσονας
if i understand what you are asking and maybe this will help to create a circularize you need 4 faces,
Screen Shot 2023-04-03 at 2.44.05 PM.pngScreen Shot 2023-04-03 at 2.44.28 PM.png
Message 4 of 12
t_aliesinriver
Thanks! Maybe I misunderstand you but I don't think that's true... I regularly use two faces and it works just fine. It just creates a hexagon instead of an octagon.
It also worked fine with the selection shown after I had combined it with another object as described in my other comment.
Message 5 of 12
Ιάσονας
i misunderstood as well i thought you were trying to creating a circle, in order to create a hole , you would need four faces,
Message 6 of 12
t_aliesinriver
Ok this is getting kind of off topic, but I'm still not sure what you mean! In my experience, you can create a circular hole with a hexagon just as easily as with an octagon.
You do of course need to smooth it afterwards, but that's the same whichever shape you start with.
t_aliesinriver_0-1680548355475.pngt_aliesinriver_1-1680548368562.pngt_aliesinriver_2-1680548490178.pngt_aliesinriver_3-1680548513229.png
Message 7 of 12
Ιάσονας
the way you are doing it is causing bad geometry with ngons
Message 8 of 12
t_aliesinriver
There are no ngons though... the mesh is entirely quads, both before and after subdividing.
Message 9 of 12
Ιάσονας
Screen Shot 2023-04-03 at 3.20.06 PM.pngthought this was an ngon but i see whats happening now the geometry is being twisted around because of the circularize
Message 10 of 12
t_aliesinriver
Oooh yes I see what you mean, yeah I just made that model as a demonstration so I didn't bother trying to smooth out the surrounding geometry
Message 11 of 12
Ιάσονας
this is how i was taught
Message 12 of 12
t_aliesinriver
I feel like both methods are just fine, it just depends on the original topology you're working with, and how much detail you need for that specific part. I use both methods regularly, as well as much larger selections of quads.
I don't think it's really possible to create n-gons with the circularize tool if they weren't there already, since all it's doing is moving vertices around, which doesn't effect the underlying topology!
