Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Change the Pivot and define it as the 0-point of the object
3 REPLIES 3
2700 Views, 3 Replies
Hey,
I want to change the pivot of an object and I want to define it as the origin of the object.
Or clearer:
Let's think in 2 dimensions only. I take a cube (side length x1 y1), set the pivot to the left upper corner and set the object to 0 0. Now I want the object to have its vertices at x0 y0, x1 y0, x1 y-1 and x0 y-1.
(sorry if it is not clear enough, my english sucks)
Is there a way to do that? It would make things much easier.
Thanks!
3 REPLIES 3
Yes, you can just freeze the transformations of the object which will bake the data into the vertices at its current position and set the matrix to identity:
Modify > Freeze Transformations
Hope it helps
Mike
mspeer
It worked, Thanks!
