Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Center Pivot and Freeze Transformation
12 REPLIES 12
Message 1 of 13
1591 Views, 12 Replies
Sorry if this is a stupid question, I wonder, when I center the pivot, it gets to one spot, but it's not until I freeze transform first and then center pivot that it gets to the real middle, why is that? What does freeze transform do to change the center of the pivot?
12 REPLIES 12
Message 2 of 13
mspeer
Hi!
Please upload a scene-file.
Message 3 of 13
in reply to: mspeer
when i center the pivot on the dragon it's not at the same place as if i freeze transform and THEN centr.
Message 4 of 13
mspeer
Hi!
Check Bounding Box before and after Freeze Transformations:
Message 5 of 13
in reply to: mspeer
Yeah, when it's not freezed then it has the right scale but doens't fit because it's not at the right location, but when I have freezed it, then it fits.
Message 6 of 13
mspeer
Hi!
There is not only one "right" position, both bounding boxes have different centers.
You can even center the pivot manual.
Just set the pivot to the place where you want it to be.
Message 7 of 13
in reply to: mspeer
the world axis is set when it's at freeze transformation and bounding box view.
I still don't understand the relationship, how come the bounding box changes because of freeze transform?
Message 8 of 13
mspeer
Hi!
That's what Freeze Transformation does, it resets the values based on world axes or in other words you loose the local transform / orientation ( based on your Freeze Transformation settings).
Just create a cube, select all faces, then enable Bounding Box display and rotate the faces (still selected).
You see how the Bounding Box changes (that's the reversed effect but related to your problem).
Message 9 of 13
in reply to: mspeer
But, so, if I freeze transform, the world space becomes object space? Because the current position is now the center?
But shouldn't the center of the object in worldspace, be the same as center in object space? Why is the center changed, just because worldspace becomes 0,0,0?
Message 10 of 13
mspeer
Hi!
This should clear it up.
Message 11 of 13
mspeer
in reply to: mspeer
Hi!
Just another example with more rotation applied.
You'll get a totally different position for the center cause of the rotation of the object in relation to the Bounding Box orientation.
Message 12 of 13
in reply to: mspeer
So when it's rotated, and without freezing transformation, the center is as it would be if the bounding box followed the rotation?
But when you freeze transform, then the center becomes where it would be if the bounding box is not rotated with the object?
Message 13 of 13
mspeer
Hi!
Correct.
When you use Freeze Transformation:
- with Rotation enabled, Maya "treats" the object as being now properly aligned to World Space axes.
- with Translation enabled, Maya "treats" the object as being now at World Space origin.
