Cannot combine
Cannot combine
amiratulj14
Message 1 of 10
Cannot combine
amiratulj14
I cannot combine and it said no skinning found to apply to the combined mesh. It's an error. Please help me fix this... :')
[Error: line 0: No skinning found to apply to the combined mesh]
Replies (9)
Message 2 of 10
amiratulj14
This is the example of the problem if you don't get it
Message 3 of 10
Christoph_Schaedl
Does this really happen on two new created cubes?
I have never seen this error before.
https://linktr.ee/cg_oglu
Message 4 of 10
amiratulj14
Yes, that is new created cubes
Message 5 of 10
Christoph_Schaedl
Have you tried to delete your prefs? Something is messed up.
Message 6 of 10
amiratulj14
pref? No no there is nothing related about them. It just something about combine and.. skinning like that? Even I don't know it means
Message 7 of 10
Christoph_Schaedl
I mean delete the preference folder in mydocuments... That will reset maya.
Message 8 of 10
jmreinhart
If you go to mesh>combine and then click on the white box it will open up a window with some options.
One of the options is a checkbox labeled "combined skinning".
If you turn it off then combining should work properly.
Once you change it in that menu it should automatically fix the button on your shelf, so you won't need to go into that menu each time.
I have no idea how that option would have gotten turned on though.
Message 9 of 10
amiratulj14
Oh thank you so much! I don't know how it turned on either haha. It's worked
Message 10 of 10
amiratulj14
I fixed it now. It doesn't matter about the pref. Thank you for trying to help:)
