Can't move Xgen guide curve control points
Mickey-G
Mickey-G
I'm not sure what happened, but all of the sudden I can't move xgen guide control points. I can select the points but they don't move. Any ideas?
Mickey-G
ugh,
I closed and reopened the file and got this error, and the guides can no longer be seen, they are in the outline, but won't display in viewport:
Importing XGen Collections...
// Error: XGen: Guide xgGuide4Shape has geometry but no vertices. Missing MakeGuide? //
// Warning: XGen(1): Invalid spline guide xgGuide4Shape with only 0 cvs. //
// Error: XGen: Guide xgGuide5Shape has geometry but no vertices. Missing MakeGuide? //
// Warning: XGen(1): Invalid spline guide xgGuide5Shape with only 0 cvs. //
// Error: XGen: Guide xgGuide6Shape has geometry but no vertices. Missing MakeGuide? //
// Warning: XGen(1): Invalid spline guide xgGuide6Shape with only 0 cvs. //
// Error: XGen: Guide xgGuide9Shape has geometry but no vertices. Missing MakeGuide? //
// Warning: XGen(1): Invalid spline guide xgGuide9Shape with only 0 cvs. //
// Error: XGen: Guide xgGuide10Shape has geometry but no vertices. Missing MakeGuide? //
// Warning: XGen(1): Invalid spline guide xgGuide10Shape with only 0 cvs. //
// Error: XGen: Guide xgGuide11Shape has geometry but no vertices. Missing MakeGuide? //
// Warning: XGen(1): Invalid spline guide xgGuide11Shape with only 0 cvs. //
// Error: XGen: Guide xgGuide12Shape has geometry but no vertices. Missing MakeGuide? //
// Warning: XGen(1): Invalid spline guide xgGuide12Shape with only 0 cvs. //
// Error: XGen: Guide xgGuide13Shape has geometry but no vertices. Missing MakeGuide? //
// Warning: XGen(1): Invalid spline guide xgGuide13Shape with only 0 cvs. //
// Error: XGen: Guide xgGuide14Shape has geometry but no vertices. Missing MakeGuide? //
// Warning: XGen(1): Invalid spline guide xgGuide14Shape with only 0 cvs. //
// Error: XGen: Guide xgGuide15Shape has geometry but no vertices. Missing MakeGuide? //
// Warning: XGen(1): Invalid spline guide xgGuide15Shape with only 0 cvs. //
Done.
// Error: XGen: Candidate guides have not been associated! HeadHair,EyelashLeft //
// Error: line 1: XGen: Candidate guides have not been associated! HeadHair,EyelashLeft //
Mickey-G
not sure what it was, went back a save file and restarted. Glad I save incrementally.
zorbs
I had the same issue, and tryed thousand things, nothing works and no one gave a good solution. What i did that works is to save the file, create a new scene (without closing), and than import the saved file. This solved the problem for me.
