Maya Modeling
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya modeling topics.
Can only select verts on my object's cage, not on the subdivision preview
2 REPLIES 2
ioannis.lazaras
574 Views, 2 Replies
So generally I put my objects on subdivision preview (hotkey 3) and work on them from there, moving verts and edges with the move/rotate tool and soft select until I need to actually apply the subdivisions.
However now when I select a vertex on subdivision preview, the gizmo for the move tool goes to where the vertex actually is on the non-divided object (or cage). This makes it really annoying and inconvenient to move verts around, as the gizmo is far from the vert I want to move on the subdivided model.
I know I probably hit the wrong hotkey somewhere or switched something on by accident, but I can't figure out what. I'm so certain that it wasn't always this way.
Tags (2)
Labels (1)
2 REPLIES 2
that´s the normal behavior. it´s just more obvious the less subdivisions your base mesh has. if you need to counter that amount of stretching you probably should consider more subdivisions in your base mesh.
I see. I guess I only noticed when I switched to a more simple model. Thanks for your help.
