When ever I seem to combine two meshes with a material one it, the entire culling just breaks and it's incredibly annoying because I have no idea how to fix it nor an exact idea how it even occurs. The culling returns to normal when I select a different material, but it doesn't work the same when I make a brand new one.
Solved by hamsterHamster. Go to Solution.
This rather looks like polygon depth-sorting problem related to the hardware rendering settings - either the Vieport2.0 settings or the ones in control panel of the video hardware.
Ensure you have Certified Hardware | Maya, Arnold, MotionBuilder & Mudbox and updated (beter - certified ones) drivers, otherwise there might be such issues.
Also, if you are on Windows, you can try to switch from OpenGL to DirectX in Preferences > Display > Viewport2.0
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
Thank you for your help, in Viewport 2.0, enabling Alpha Cut Prepass fixed my issue!
I spoke to soon, while this does fixed the clipping issue, the UV's no longer visibily change.
Also I am already using DirectX, but I will see if updating Maya will fix my issue.
Edit: Multi-cutting seems to fix it.
