Hey, I'm trying to model my Xbox one it has like a drain sort of mesh on the top (see pictures attached)
I created a long thin rectangle rotated and duplicated special with the hope to then use booleans difference on the top face it says must be two polygons selected so I created half an Xbox and duplicate specialed that so I could booleans special the right half as a polygon selection instead of a face selection it now runs without error but doesn't give desired result it just reduces my mesh from 70 back to 1 rectangles, any advice? This is exactly the kind of challenge I wanted for my modeling practice but I really can't work it out
Hi @onliconnect
You're pretty close to getting it but I went ahead and made a video for you on how to do this !
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
