Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hallo
I am desperate because that doesn't help.even if I restart Maya it still selects the faces on the other side. Any other solution?
thank you
Regards
Martin
One year ago, tho still pops up in search. Here it goes:
Set Camera Based Selection to "on" our "auto". You can acces it from Modeling Toolkit window or from double click on selection tool under Common Selection Options).
PS You don't have to cull backfaces in display just for selection. If you want though, I find Display>Polygons>Backface Culling not working sometimes. Try Shift+RPM>Polygon Display>Backface Culling – this one should work.
By far the best answer for not selecting faces or vertices you don't want, (hidden on the backside.) Why does backface culling even exist if it doesn't work?
