- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have to first apologise for this kind of time wasting, this is the 4th model I've ever worked on and there's a lot of painful mistakes and habits I'm trying to work on. I've tried to google this issue but I really don't understand any of the terminology and I'm ultimately completely stuck on this.
Attached is a model I've made, upon exporting it into either .fbx or .obj I keep finding small issues with the model. In the .png I've attached is the error that occurs when it's a .fbx and it's also in this spot that one of the .obj errors occurs where there's simply a hole in the model. Also on the .obj is lots of errors with the fans, on the vehicle's top, with the "hole" being covered partially or wholly depending on how what program I use to open the .obj.
Is there any way to preserve the work I've done and get it exported safely? I've never had any issue with my other models and they weren't simple either. I'm aware I'm buggered up comprehensively, I don't think I should even try to explain what the hell I've done in the Outliner.
I'm just hoping someone can see some simple error in the model or exporting process that I've missed, because at this point I'm just stumped.
Hope you can help,
Hugh
