Announcements
What's the hotkey for Smoothing Approximation on Mac for Maya 2017?
 I'm aware that the hotkey is "3" on windows, but the "3" hotkey is not working on my mac.
mspeer
Hi!
Check with Hotkey Editor.
So I looked and apparently it is supposed to be "3'? But it doesn't seem to be working?
mspeer
Hi!
You could also try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
... i doubt this will change anything, but it's worth to try.
Does it work if you enable it manually in Attribute Editor?
Does it work with a new object in a new scene?
Maybe there is a problem with your keyboard?
Never mind got it to work. Thank you.
