way to two sided faces
I've modelled a face using a plane native. Is there a way to creating two-sided faces so they can render? - see crown of the head pic. For rendering purposes it goes into a game engine.
Thanks a lot for your help, Sergio
Its_jay
Hi
If you want to render two side object in game engine , make sure to turn on (two side object) checkbox in material editor
Could you give a bit more detail on this? Unity doesn't have a 'two sided object' check box and it's not entirely straightforward in Maya material editor either. Thanks
@Its_jay wrote:
Hi
To add a bit more detail to this after many hours of trying to find the solution for double sided models in Unity (imported from Maya) - (In Unity) make sure your shader dropdown selection is 'Particles/Standard Surface' and click 'Two Sided' under Main Options - it is not available on the standard shader menu.
